how do i permanently move an objects rotation point?
COW Forums : Adobe Photoshop
00ziggi
on Feb 4, 2007 at 9:20:31 pm
so that it always rotates around a point other than it's center?
thanks!
jimmybee500
Re: how do i permanently move an objects rotation point?
on Feb 5, 2007 at 12:01:38 pm
You can't do it permenently I don't think..it resets to the middle each time you re-transform.
however..just had a thought, if you save it as a smart object then I *think* it will remember..try it. Not in front of PS myself right now.
*Production Studio Premium / *Combustion 3
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
Mike Gondek
on Feb 6, 2007 at 8:38:22 pm
Yuo have the rubiks cube in the task bar whcih has the basic 9 references points.
If you need a diffent possition, you may want to create a dummy layer mask, where the center is the position you want to transform on, and make the layer mask include everything in the layer (works perfectly on the rare occasion I need to do this). You can temporalily unlink the layer mask from the layer if you need to recenter the layer against the mask.
