How to flatten a multiplied layer?
COW Forums : Adobe Photoshop
Steve Kirby
on Dec 21, 2006 at 8:58:14 pm
This is probably really simple but I'm no PS expert. I have a grayscale layer in multiply mode. I want to 'flatten' it so that it makes the multiplication permanent and becomes a semi- transparent layer. All white pixels become 100% transparent and all 50% grey pixels become 'black' at 50% transparency etc etc. in 'normal' transfer mode. Thanks in advance
Vintendo
Re: How to flatten a multiplied layer?
on Dec 22, 2006 at 5:59:08 pm
Well, you're on the path to expert status... Anyway, It sounds like you want Transparency to behave the same as Multiply, I don't think you'll be able to do that and achieve acceptable results.
Could you - Duplicate the PSD to create a stunt file, than flatten just the components that make up this Multiplied element - The multiplied layer and the target layer. Than, reinsert this prepared and flattened layer into your project?
Of course, you could do this within the original file. I just like to do stunts in another file. : )
