anit-aliased problem with marquee tool
COW Forums : Adobe Photoshop
brettw
on Nov 19, 2006 at 8:20:26 pm
Hello,
Normally when I use the rectangle marquee tool, I believe anti-aliased is turned on. The marquee tool isn't functoning like it usually does, and I noticed that anti aliased is turned off. I would like to turn anti-aliased on, to see if that allows the marquee to work like it normally does, however, it won't even let me click the anit-aliased box in the toolbar/options bar.
I am not sure if I acidentally clicked something or what, but this is driving me nuts.
Andrew Kramer
Re: anit-aliased problem with marquee tool
on Nov 21, 2006 at 11:09:24 am
Using the shape tool there are 3 options, vector-filled shape, vector shape, and raster shape. the raster shape is the 3rd option on the right in the top left corner of the options. I think when you have this selected you will be able to turn on aliasing if it isn't already on.
Andrew Kramer
Richard Harrington
on Nov 26, 2006 at 11:47:59 pm
Rectangular Marquee never has anti-alias (only feather)
Eliptical marquee has both...
Check if you have a high feather value insterted by mistake
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
Andrew Kramer
on Nov 29, 2006 at 10:57:42 am
For some reason I was thinking about the shape tool...
