Engrave effect on leather texture
COW Forums : Adobe Photoshop
edr
by
on Nov 19, 2006 at 4:12:27 am
I want to create the effect as if my logo was engraved into a leather texture. I trying using bevel emboss drop shadow and inner shadow but all of my results makes the logo look raised instead of engraved. Anyone know of a good tut or technique for leather. I have attached a link to an example. It is the Ivette Gerstenschlager.pdf file.
http://www.layersmagazine.com/downloads/mayjune05/design_makeover.zip
Andrew Kramer
Re: Engrave effect on leather texture
on Nov 21, 2006 at 11:06:26 am
http://www.videocopilot.net/leather.zip
Here is a quick little layer effects way to do it. I think it has to do with setting the bevel to outer and making it go down. also playing with the settings you should see how to make it work for you.
Good Luck,
Andrew Kramer
edr
by
on Nov 21, 2006 at 1:14:51 pm
Thanks alot!!!!
