Could not save "filename.psd" because of program error - help
COW Forums : Adobe Photoshop
jeremy
on Nov 8, 2006 at 7:58:33 pm
when i try to save a file in photoshop cs2 to a firewire attached harddrive, i get the error "Could not save "filename.psd" because of program error". after effects doesn't seem to have this problem saving to that drive and if i save the ps file to my desktop and move it over it works. any ideas how to stop this error?
os 10.4.8, 2.5 Ghz quad power pc, ps9.0.2
scottgfx
Re: Could not save "filename.psd" because of program error - help
on Nov 10, 2006 at 4:03:54 am
I've often had this same issue with Photoshop 7. In fact, I found your message because I was doing a Google search on this very problem. I was having the error when saving to an internal RAID that was connected to the motherboard ATA channels of a G4. I'm now having the same problem when saving to a G-Raid attached to a PCI FireWire-800 card. I can however save to boot drive.
I don't think I've had this problem with CS2... yet.
MarkCarrara
on Nov 13, 2006 at 6:06:38 pm
Interesting. We are having a similar issue with Elements. Our district's yearbook staff uses Elements and can save to a local drive, but not the network drive unless I gave them full control permission. When they had modify only they could save to the local drive then drag to the network drive. I wonder if there is a bug in the save routine?
Mark
