When I Use the Line Tool....
COW Forums : Adobe Photoshop
Crunker
on Oct 31, 2006 at 11:48:04 pm
When I use the line tool, a new layer is automatically created. I don't particularly mind this. However, I can't see what's in any other layers I've created. The eye button is on so theoretically I should be viewing all other layers.
I want to be able to make new lines within the same layer, or, failing that, be able to view the contents of pre-existing layers. Thanks in advance.
Andrew Kramer
Re: When I Use the Line Tool....
on Nov 3, 2006 at 5:42:16 pm
If you hold down shift when creating filled-vector lines it will add the shape to the same layer.
