How to limit cut-put tool to fix ratio
COW Forums : Adobe Photoshop
giorgio
on Jul 20, 2006 at 9:18:24 pm
how can i force the cut-out tool to a fix size, e.g. 2:3, regardless of width*hight and pixel.
If I add values in the fields for width and hight, the software defaults always to a measure (inch or cm).
Giorgio
Erik Ivar Olsen
Re: How to limit cut-put tool to fix ratio
on Aug 3, 2006 at 5:32:57 pm
In Photoshop? I usually use the marquee tool first. With that, you can select a fixed aspect ratio. When I have the marquee tool as I want it, then I use the Crop item in the menu, not the crop tool.
