This you are not goingto believe.
COW Forums : Adobe Photoshop
DeaditteX
on Jul 6, 2006 at 9:46:30 pm
I cannot find the setting that has beenchange in Illistrator. We can import the first in a series of 'save as' files (ie titles01, works fine, but titles02 doesn't work at all)
What happens is wene w pull 01 in to after effects it shows up fine. But 02 imports but the text is no longer their we haven't changed any of the illistrator settings and cannot figgure out where the poblem is but I have to assumeit's a setting in illistrator that is keeping after effects from noticing the text is there and returning the cocument blank?
Mike Gondek
Re: This you are not goingto believe.
on Jul 11, 2006 at 6:03:55 pm
Convert your text into outlines, and see if that helps. You may have a font conflict.
bilart
on Jul 13, 2006 at 8:49:29 am
yes Mike is right, shoud be a font conflict, and Dude, please run the spell check before you post, I am doing mistakes myself but this is an outrage
