Data sets, Text replacement and vertical alignment.
COW Forums : Adobe Photoshop
chris gormlie
on Jun 8, 2006 at 10:47:55 am
Hello,
I am using PS-CS2 to generate a few thousand stills for an interactive DVD. I am pulling text from a CSV file in the format of;
"question","answer a","answer b","answer c","answer d"
This data is happily being pulled in by PS as a dataset, and this data set is happily replacing 5 defined paragrah text layers. I can then export the whole thing to imageready and output all my datasets as files.
Its all working as I hoped it would, however...
As the length of the text for the questions and answers can vary from 1 line of paragraph to 4, I need a way to automatically vertically center the text within the paragraph box. I can horizontally align no problem, but I just cant seem to find a way to vertically align text within the paragraph box. I really dont want to have to export it all to thousands of PSD's and do them manually.
Anyone here have any clues as to how I can vertically centre text in a paragraph box either in PS or Imageready? It would save my weekend for watching the world cup.
cheers.
Mike Gondek
Re: Data sets, Text replacement and vertical alignment.
on Jun 12, 2006 at 8:53:56 pm
There is one way, but you would have to convert the area text layer to a shape layer (layer>>type>>convert to shape). Then create a shape layer the size of the entire document, link the 2 layers, and then with the fullpage shape layer selected use the vertical align.
