Create BBall Court from Scratch
COW Forums : Adobe Photoshop
Jim Zito
on May 19, 2006 at 12:13:26 am
Hi. Just wondering if anyone's attempted to create the floor of a basketball court in Photoshop. I've been doing some trial and error but having no success. I know it's probably pretty tricky to get the subtle nuances and textures right, but I was just curious if anyone had any suggestions. Thanks for any help!
Jim
Jeff Cochran
Re: Create BBall Court from Scratch
on May 24, 2006 at 5:28:08 pm
Here's a way to start with the wood grain.
Create a canvas and apply noise to it. Use a motion blur with the angle set on 0 and adjust until the noise has been stretched out to a lenght of your liking. You color this in a number of ways. I like to create a new layer with a wood color with a transfer mode of "color".
From there you add othere filters to the texture like sharpen or Gaussain blur. Just play around with it to get the texture you like.
From there you can add a subtle gradient, use some noise to some sharper highlights. You can also create a pattern to match the boards and give them a bevel emboss, then try using a transfer mode (like overlay)for the layer.
Hope some of this helps
Jeff Cochran
http://www.jeffcochrandigitalartist.com/
Jim Zito
on May 25, 2006 at 2:41:08 pm
Hey Jeff. Thanks a lot for the help! I'll give it a try.
Take care,
Jim
