Chroma offset/shift
COW Forums : Adobe Photoshop
DeathWolf
Chroma offset/shift
on Feb 20, 2006 at 6:29:46 pm
Hello all,
I am searching for a plugin or way to correct a chroma offset/shift in photoshop.
This is usually characterized by a purple/pink look on one side of the edges and a yellow/green one on the opposite side. Usually caused when the picture goes through chromatic aberations or analog yuv/yiq transfer i have noticed it on some of my scans lately without being able to fix it in anyway.
So if anyone knows any plugin, let me know.
Thanks a lot,
Best regards,
Paul-Kenji Cahier
Richard Harrington
Re: Chroma offset/shift
on Feb 25, 2006 at 6:16:20 pm
Your scanner is broken... faster to repalce it
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
