Changing a file from 72 dpi to 300 dpi, Can any of you experts help a novice?
COW Forums : Adobe Photoshop
jennifer
on Feb 19, 2006 at 10:34:05 pm
Hi.
I need to make a psd file 300dpi. It is presently 72dpi. Can anyone recommend an easy way to do this or do i have to start from scratch? Thank you for your help!
Del Holford
Re: Changing a file from 72 dpi to 300 dpi, Can any of you experts help a novice?
on Feb 21, 2006 at 10:44:53 pm
Image>image size>change 72 to 300>enter. Is that what you need?
Del
fire*, smoke*, photoshopCS2
Charlotte Public Television
jayse
on Mar 3, 2006 at 2:41:18 am
it will most likely look like heck tho - so I'd suggest recreating it from scratch at the higher resolution. Think of it as really good photoshop training to have to do it all over again. the Lesson is: don't do it at 72dpi!
Another thought tho - is that this could be 72dpi at 33inches big. If that's the case - following Dels advice above, add in that you don't want 'resample' turned on. This will change the dpi to 300 without loss of quality (and result in a smaller print size)
hope that helps!
// jayse
Ultimate After Effects Video Training CDs
Free Photoshop CS Video Tutorials
