Multiple Alpha Channels question
COW Forums : Adobe Photoshop
Jon
by
on Feb 16, 2006 at 11:30:02 pm
Sup guys,
I have a quick question about a PSHOP document containing three different alpha channels. So right, I have three different alpha channels each masking a different section of the screen when needed. The "save" file needs to be a TARGA file saved at 32 bit to of course hold the alpha channel. Now when I save the file with the desired alpha channel(out of the three in the channels palette) as a TAGRA it does not take the channel. If it is saved with only one alpha in the pallette(not three, I deleted the other two) it of course holds the channel. Pheww, now is there a way save a targa and get the alpha channel I want without always adding and deleting channels?
Richard Harrington
Re: Multiple Alpha Channels question
on Feb 17, 2006 at 12:16:40 am
Nope.... Targas and Picts only recognize first alpha channel
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Jon
Merging Multiple Alpha Channels question
by
on Feb 17, 2006 at 2:36:24 am
Ahhh....I see. Thanks. On another note. Is it possible to merge two alpha channels? -the HELP says they need to be two different grayscale images with alpha channels- true??
thanks for you help
jon
Richard Harrington
Re: Merging Multiple Alpha Channels question
on Feb 17, 2006 at 2:43:14 am
Two different ways
calculations command or
Cmd click on one, then shift md click on other... then click new channel button to create a channl using current selection
Jon
by
on Feb 17, 2006 at 9:13:52 pm
Cool thank you Richard!
