batching converting in Photoshop CS2
COW Forums : Adobe Photoshop
benhanjack55
on Feb 14, 2006 at 9:37:47 am
I have a whole lot of files that i want to burn to disc for arhival purposes..These are big images(at least 68 mb).THey were scanned as tiff files and non compressed.As it is, even a dvd will fill quicky so i really need to reduce the size of these shots so that I can get a couple of hundred on a dvd.
Is there anyway that i can reduce the size of these images(batch) utilizing cs2 without having to rescan the lot again (which i can do) but will take a lot of time.I realise that u can batch convert in photoshop but is there anyway to batch "downsize"
THis may have been an obvious/dumb question but i would appreciate any input
THanku in advance
Wayne
Richard Harrington
Re: batching converting in Photoshop CS2
on Feb 14, 2006 at 1:28:25 pm
Look up the image processor in help menu
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
benhanjack55
on Feb 14, 2006 at 2:38:26 pm
Cant get image process to function
get error as follows reference error.this dlgMain ddset.on change is not a function.810.
Richard (or anyone)have u ever heard of this???Should i try and do a reinstal as it may have not installed the script properly when i first instaled or is there something here that i'm missing???
Richard Harrington
on Feb 14, 2006 at 2:58:16 pm
I would reinstall
