Composting Photo with Black Bg onto Black Background for print?
COW Forums : Adobe Photoshop
llll--Kia
on Feb 10, 2006 at 11:25:58 am
I'm designing a set of DVD covers where the feature photos on the fronts covers have black backgrounds. I have adjusted the levels of the photos so that the blacks look the same as the full black background. However when I combine the layers and increase the brightness (only to check how close the match is) you can still see a difference between the two. I have tried fading the edges of the photo into the background but I am still concerned when this goes to print that the two different tones of black will show up.
Any suggestions would be much appreciated
Underbelly
Re: Composting Photo with Black Bg onto Black Background for print?
on Feb 13, 2006 at 11:21:32 pm
What program are you doing this in? Photoshop? If so, just take a sample of both blacks. if they are the same CYMK values, you'll be ok. You can't do it by sight.
