key command shortcuts not working in photoshop CS
COW Forums : Adobe Photoshop
chickapea
on Jan 20, 2006 at 11:03:06 am
The key commands in my version of Photoshop CS are not working. Shift works to keep things in proportion but none of the Ctrl + commands work nor does moving things with the arrow keys...
Richard Harrington
Re: key command shortcuts not working in photoshop CS
on Jan 22, 2006 at 9:17:55 pm
Trash your PS prefs and restart... also look to see if you've installed any thuird party extensions (without any OS info its hard to help you)
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
chickapea
on Jan 23, 2006 at 11:33:45 am
Where do i find the Prefs files? im using photoshop on Windows Xp.
It's not in program files.. I haven't installed any plug-ins or anything...
