Question about changing text in Photoshop?
COW Forums : Adobe Photoshop
eric
by
on Jan 13, 2006 at 6:23:00 am
I have several photoshop file with text that I need translated to different languages.
Since the translator probably wont have photoshop can I have them translate into a text file then copy that translation into my original photshop file assuming I have installed the languages into my application?
Thanks Eric
Richard Harrington
Re: Question about changing text in Photoshop?
on Jan 13, 2006 at 12:20:04 pm
Yes... if you have teh correct fonts loaded and the ones you've chosen support that character set...
I'd be sure to get a hard copy from the translator so you can compare
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
jayse
on Jan 18, 2006 at 3:06:51 am
Rich is right - make sure to get it proofed by the translator after it's in PS. Things get a little weird in my experience even with the same fonts - especially if going in and out of MS Word.
Good luck and good proofing,
// jayse
Ultimate After Effects Video Training CDs
Free Photoshop CS Video Tutorials
