nerds to attention!
COW Forums : Adobe Photoshop
nerds to attention!
on Jan 12, 2006 at 1:16:46 am
im doing a batch action comman on an image sequence. the images are tif's. the action involves generating an alpha chanel. the problem: every time photoshop saves an image it comes up with a dialogue box requesting me to manually specify the tif options; i have to do this for every single file. there are thousands. is it possible to make photoshop remember the tif options (compression, transparency, preserve layers etc) or am i going to have to approach this from a diferent angle?
Richard Harrington
Re: nerds to attention!
on Jan 12, 2006 at 1:25:09 am
Either record the close and save as part of the step and check the ignore Save As in the Batch or use the Image Processor Script with CS2 and specify to include the action in the save
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from
edit - produce - direct -
© 2018 All Rights Reserved
