CS 2 RAW?
COW Forums : Adobe Photoshop
Amish Ed
CS 2 RAW?
on Dec 27, 2005 at 9:56:21 pm
I shoot a lot of teeth on black backgrounds, and models on white backdrops and both types of images really throw off the Auto finction. It's really anoying to have to always pull down the menu and turn off the Auto Adjustment. I have my own image settings profile, but can't find a way to make RAW default to that, so I'm wondering if there's a way to disable the Auto Adjustment feature in the RAW converter? Checked the archive, but no luck.
Amish Ed
Dual 2Ghz G5, 4GB, running 10.3.6 w/QT 6.5.2, Black Majic DeckLink, AE Pro 6.5 w/BCC and Invig. 3D, PS CS2, AI CS2, FCP HD
Richard Harrington
Re: CS 2 RAW?
on Dec 30, 2005 at 4:21:46 am
You can color correct first..then apply settings to others... also can Use Image Processor Script... details on both in Onlione Help for step by step
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Amish Ed
Re: CS 2 RAW?
on Dec 30, 2005 at 4:00:25 pm
Thanks Richard, sounds like I'll just stick to the same way. The auto settings are usually so far off it's easier to do it myself.
Amish Ed
Richard Harrington
Re: CS 2 RAW?
on Jan 2, 2006 at 11:46:49 pm
I amnot saying auto... you can tell Photoshop to use the corections from the first image as the corrections for the rest coming from the same "roll"
Amish Ed
Re: CS 2 RAW?
on Jan 3, 2006 at 6:59:04 pm
Gotcha Richard. I do make use of that feature which is very helpful.
Amish Ed
