photoshop to indesign?
COW Forums : Adobe Photoshop
on Dec 17, 2005 at 7:07:51 pm
i'm having troubles transfering images that are not a square or rectangle into indesign. it shows up in indesign with a white box around it no matter what I try to do. how can i fix that?
Kim Mackenzie
Re: photoshop to indesign?
on Dec 17, 2005 at 8:35:48 pm
Indesign should recognize Photoshop transparency.
It's probably your Display settings - InDesign is showing you a rough preview of the Photoshop file to save screen redraw time so your machine will run faster.
In InDesign, go to the View menu > Display Performance > and switch it to High Quality Display.
You can also change the display quality for a single object by right-clicking or control clicking on the object and setting it in the popup menu.
© 2018 All Rights Reserved
