How automate a selection and blur effect?
COW Forums : Adobe Photoshop
Roman
on Dec 12, 2005 at 11:13:33 pm
Hello,
I have created a batch of .psd images from a video clip at witch I want to re-touch the background using the blur tool to create a shallow depth of field effect. When I record the actions, and apply the automate batch action I have created, it does not affect the images I want to alter. Does anyone know how to achieve this?
Thanks a bunch,
Roman
Roman
http://www.romanjaquez.com
Richard Harrington
Re: How automate a selection and blur effect?
on Dec 14, 2005 at 12:06:05 am
Can't autoamte hand tools.. only menu commands
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Roman
on Dec 14, 2005 at 8:58:06 pm
Thank you Richard,
Is there a software or method to achieve the DOF I tryied in Photoshop?
Roman
Roman
Richard Harrington
on Dec 20, 2005 at 1:02:33 am
Lens Blur filter... you can try to automate creating the alpha channel for the depth matte... if photos are similar.. use calculations command
Roman
on Dec 20, 2005 at 4:22:26 am
Thank you Richard,
That sounds a bit advance for me... but I am sure I can figure it out. Any tips on "How to" about your comment?
Roman
Roman
