Does anyone have any tips on making a website primarily in photoshop?
COW Forums : Adobe Photoshop
DanielHaskett
on Dec 8, 2005 at 6:49:58 pm
Hi there,
Basically Im having a problem making a website where i am primarily making it in Photoshop/ImageReady and using dreamweaver mainly for links and uploading. If you go to http://www.erinbarry.co.uk you can see the beginnings of my site and hopefully understand the problem. The only working link is Portraits, so if you go there you can see that when you click on a photo, the rest of the thumbnails dont work on the next page. Basically Im making every single image as a different webpage because I dont want to use frames. This however means that for every image i am having to redo the links for every thumbnail....does that make sense?
I was just wondering if anyone knows anyway of making the links fixed for all the pages in imageready or dreamweaver? Its very time consuming at the moment! Maybe I should just use frames...but i find them limiting.
Anyway hope that someone can help!
Cheers
Dan
seth
Re: Does anyone have any tips on making a website primarily in photoshop?
by
on Dec 10, 2005 at 7:59:01 am
Sounds like a job for Adobe GoLive. Check out the options for using "Components." They are like mini webpages that can be inserted into other web pages. When you update the component, all the rest of the page that contain the component get updated automatically.
seth
by
on Dec 10, 2005 at 8:03:41 am
By the way, components are not the same as frames.
These changes are very time consuming to manipulate in Photoshop/IR. You may want to check out a bunch of books to learn some HTML.
PS - your site is looking pretty cool.
seth
by
on Dec 10, 2005 at 8:03:44 am
Jim
by
on Dec 10, 2005 at 1:26:10 pm
Have you checked out "Sitegrinder"?
http://www.medialab.com/sitegrinder/
It uses Photoshop for the whole design.
renato
sitegrinder?
on Dec 11, 2005 at 3:14:24 am
Hello Jim,
Thats a really amazing plug-in... I got the demo version from the site, and I have zero knowledge on html, but I was able to make some buttons with mouse over in less then 5 minutes.
have you used this software before? I was trying to make custom shape buttons and apparently it has to be rectangles...is it possible to make custom shaped buttons with the plug-in? I can draw any shape, but it places it inside a rectangle and in the end some parts that are outside the button can be clicked too...any solutions for that? hope it makes sense..
thanks
renato
Jim
Re: sitegrinder?
by
on Dec 13, 2005 at 5:51:37 pm
Sorry, but no, I haven't used Sitegrinder myself. I came across it a while ago when I was looking into web design software and it seemed like a great program. I still haven't gotten into web design so I have nothing to compare it to.
Good luck, Jim
renato
Re: sitegrinder?
on Dec 13, 2005 at 8:29:58 pm
Hi Jim,
Thanks for the reply... I found out the answer at the sitegrinder forum and sadly it doesnt work for what I need, but its definetly worth checking out, I couldnt believe how easy this plugin works..
thanks for the tip anyway
cheers
renato
Ragno
on Dec 13, 2005 at 9:27:26 pm
try this site:
http://www.kromefx.com/index.php?page=vt&id=76
joefeng
on Dec 15, 2005 at 7:57:48 pm
How about just using one of the pages as a template and then duplicate it and swap out the picture? For example, take this page "http://www.erinbarry.co.uk/Portrait%20pages/lady.htm" and duplicate it. Then change the featured photo to another one and rename the page.
If I understand your problem correctly, that should take care of it.
kotias
Wonderful tool will decide your trouble
on Dec 17, 2005 at 7:10:37 am
There are wonderful tool for batch multireplacing.
http://www.painterscase.com/web_design/utils/webut_advancedfindandreplace.p...
