HDV illustrations are squished after import into FCP
COW Forums : Adobe Photoshop
Cardinalman
on Dec 4, 2005 at 6:25:50 am
I read that there was no need to change the pixil ratio when importing into final cut when you choose the HDV preset with square pixels. Why is mine squished top to bottom. Anyway, more important is how can I change the pixel ratio to import the illustrations into FCP so that they look normal?
Mike
Ben Insler
Re: HDV illustrations are squished after import into FCP
on Dec 7, 2005 at 10:26:11 pm
There's no need to change the pixel ration if you're importing your image into an HD sequence in FCP (because HD works with square pixels). Make sure your FCP sequence and pixel aspect ratios are set to HD and not DV (click on your sequence and press command+0).
-Ben
