Command "De-Interlace" not currently available
COW Forums : Adobe Photoshop
phil
by
on Dec 1, 2005 at 3:09:45 pm
Photoshop CS
I've set up an action that first deinterlaces a .png file & then closes it. When i try to batch a folder of .png's with this action, it gives me the message: Command De-Interlace not currently available. What does this mean?? & how do i fix this??
thanks!
Mike Gondek
Re: Command "De-Interlace" not currently available
on Dec 3, 2005 at 6:21:10 pm
You image might be in CMYK. Deinterlace does work though on 8 or 16 bit images.
Is the command available if you try to use it on the image it gets stuck on in the action?
