Alpha alpha alpha question
COW Forums : Adobe Photoshop
andrew hill
on Nov 30, 2005 at 10:22:26 pm
I've exported an image sequence (millions of colors+alpha) out of after effects, the footage is keyed video
(thus a subject with no background) but I'm having problems with photoshop recognizing the transparency of each file in the image sequence, even if the files have an alpha channel (premultiplied or straight).
Does anyone know of a good solution? I feel like I'm not interpreting the files correctly in photoshop. I might be wrong.
Any help would be appreciated.
drew
seth
Re: Alpha alpha alpha question
by
on Nov 30, 2005 at 10:50:16 pm
For working in photoshop with transparency, I typically render a PNG sequence from AE.
utah dvd replication - stotion.com
andrew hill
on Dec 1, 2005 at 8:15:32 pm
Seth thank you man.
I knew this had to be possible.
Thank you thank you thank you.
drew
