skid marks
COW Forums : Adobe Photoshop
firewireflow
skid marks
on Nov 28, 2005 at 2:23:50 am
hi
i created some skid marks in photoshop....the view would be from above...no i want to add the skid marks into picture with a winding road...is there a way to bend the skid marks so the would fit a curve in road (the skidmarks i created a straight)...like drawing a path and use that as a reference for the skid marks...any ideas?
thanks so much
florian
renato
Re: skid marks
on Nov 28, 2005 at 5:28:09 pm
if you have cs2, you can try to use transform > warp and just bend the marks to fit the road...might not be the best way to achieve what you want, but until someone else posts a better solution it might be worth a try..
good luck
renato
Kim Mackenzie
Re: skid marks
on Nov 28, 2005 at 5:32:22 pm
Filter > Distort > Shear will also do the trick. Although it's frustrating, because you don't have a lot of control, and the preview doesn't show how the layer you're distorting looks with relation to the layers below it.
k
firewireflow
cheers!
on Nov 28, 2005 at 6:33:32 pm
thanks very much!
