Fast scanner with dust & scratch removal
COW Forums : Adobe Photoshop
Morris O.
on Nov 22, 2005 at 12:57:06 pm
Looking for a FAST scanner with good dust & scratch removal that will work on regular photos. Any suggestions?
Thanks.
Richard Harrington
Re: Fast scanner with dust & scratch removal
on Nov 22, 2005 at 1:22:52 pm
If you want fast, look to Firewire connection (over USB2)... but you shoudl give your price range when looking for recommednations
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Del Holford
on Nov 22, 2005 at 4:02:23 pm
While Richard pointed out you didn't state a price range, if you can go the freight the Epson Expression 1680 is an excellent scanner. It has a negative/positive slide adapter with it and works with SilverFast scanning software plug-ins for Photoshop. It can orient the picture anyway you want and has several settings for dust and scratch removal and various settings for scanning the object up to 16 times to get the best scans. The price on CNET's Shopper.com is around $1K for the pro version.
HTH
Del
Morris O.
on Nov 22, 2005 at 8:22:08 pm
Thanks Richard & Dell,
My price range is below $500 but below $300 would be better.
Morris
