Non square pixel conversion
COW Forums : Adobe Photoshop
renato
on Nov 6, 2005 at 12:51:49 pm
Hello,
I have about 200+ images that I need to bring into Premiere for a simple slide show. They are all different dimensions, but they are all square pixels. I need to convert all of them to non square, since they are showing up completely distorted in Premiere.
I have no idea on how to do it with all the different sizes I have, and I dont want to resize each and every image manually.
Is there a way to automate this? hope my obvious confusion on the subject doesnt make my question too unclear..
thanks for any help or ideas
renato
Richard Harrington
Re: Non square pixel conversion
on Nov 6, 2005 at 2:41:07 pm
Would help if you told us WHICH version of Photoshop you are using
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
cow
renato
on Nov 6, 2005 at 2:59:48 pm
Sorry Richard, bad mistake.. I am using CS2, and I had no idea it came with Video Actions. I just found it on the manual.. I tried "DVD Slideshow NTSC Standard Inset" and apparently my problems are solved.
Any ideas or comments if this is a good aproach are highly appreciated. Thanks again for helping me out.
renato
Richard Harrington
on Nov 6, 2005 at 6:28:12 pm
Since I wrote those Actions.. they were going to be my suggestion (grin) if you had CS2....
You can also use the Place command and mannually place a bunch of images into a non-square comp and size by hand if you want.. the NS conversion happens upon the Place command
renato
on Nov 6, 2005 at 6:37:44 pm
oh wow..thats really cool!!
they worked perfectly for what I needed. And thanks for the tip about the place command. I know its gonna be usefull in future projects.
sorry again for not mentioning the version and thanks for the great actions!
renato
