Multiple files into one PSD file
COW Forums : Adobe Photoshop
on Nov 4, 2005 at 7:54:29 pm
Does anyone know of a way I can select muliple jpegs in a folder and have them automatically import into one psd file seperating each jpeg onto it's own layer and keep the original file names with that layer? I have done this done this in a back door method by pull all my files into After Effects and creating a comp then saving that comp as a PSD file but this doesn't work with the current files because some of them are CMYK wich After Effects does not read.
Richard Harrington
Re: Multiple files into one PSD file
on Nov 5, 2005 at 11:18:30 pm
If they are sequentially numbered... you can import them in Image Ready into one document
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from
edit - produce - direct -
© 2018 All Rights Reserved
