Can't open .psd file and import into CS at the same time...
COW Forums : Adobe Photoshop
brian
on Nov 4, 2005 at 12:48:25 pm
It used to be that I could double click on a .psd file...it would open CS and also open itself. Now, when I double click, it opens CS, but I have to manually navigate to the file thru the browser. Nothing changed...how can I get this operation functional again???
Mac 733,1.25 GB ram,Photoshop CS
Richard Harrington
Re: Can't open .psd file and import into CS at the same time...
on Nov 5, 2005 at 11:17:46 pm
It was part of upgrading your OS (I am guessing you are on mac and went 10.3>10.4 or soemthingliek that with a clean install).
Easiest thingto do is back up your filters and presets fodler... reinstall PS.. and move your custom stuff back to get the sytsyem extensions installed
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
