CS2 multiple images?
COW Forums : Adobe Photoshop
Kennon Shain
on Nov 4, 2005 at 6:28:09 am
Hello,
I'm an extremely novice Photoshop user, so please forgive my simple question. But I heard that with CS2, you can scan in multiple images together, and then CS2 will separate the images for you. If I could scan in 6 pictures at once, instead of 1, that would save ridiculous time. Is this possible?
I'm currently using CS1, but would make the upgrade if that was the case.
If not-are there any good scanning programs for Mac OSX (10.3.9)? I'm producing more slideshows, which means LOTS of scanning.
Thanks for any advice-
Kennon Shain
PowerMac G4 (Quicksilver)
Dual 1 GHZ
1.5 gig RAM
OSX 10.3.5
Final Cut HD
Richard Harrington
Re: CS2 multiple images?
on Nov 5, 2005 at 11:16:37 pm
File>Automate>Crop and Straighten is the command.. you can scanmultiple at once that run that command to sepearate them into individual docuemnts
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Kennon Shain
on Nov 6, 2005 at 12:14:41 am
Much thanks-
It looks like I have that command in CS1, so I'm going to give it a shot tonight-
Ken
Dual 1 GHZ
1.5 gig RAM
OSX 10.3.5
Final Cut HD
