Channel Mixer
COW Forums : Adobe Photoshop
Orthanc
Channel Mixer
on Nov 1, 2005 at 8:29:34 pm
How come, that when I use the channel mixer to create a monochromatic image the result is always darker than expected?
For example: If I just look at the red channel of an RGB image, the resulting black and white image is much brighter than when I use the channel mixer and set it to 100% red and 0% green and blue.
Orthanc
I am talking about Photoshop CS2 by the way, sorry. n/t
on Nov 1, 2005 at 8:30:41 pm
Richard Harrington
Re: Channel Mixer
on Nov 2, 2005 at 12:35:45 am
Becuas you are placing the red Channel data into more channels when you are done...
try Calculations comman instead
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
