adding effects to multiple files at once (i.e. image sequence from AE)
COW Forums : Adobe Photoshop
emf241
on Oct 30, 2005 at 3:41:24 am
is there any way to add effects to multiple files at once, or in some way where its not done manually file by file? i've done stuff by exporting image sequences from AE then doing each file individually, but its obviously time-consuming, and i'm hoping there's a better way. any help is great, thanks.
Richard Harrington
Re: adding effects to multiple files at once (i.e. image sequence from AE)
on Oct 30, 2005 at 4:49:43 am
Look up actions and the Batch Command
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
