Can't get out of "FAUX BOLD" setting on fonts!
COW Forums : Adobe Photoshop
Stu Aull
on Oct 23, 2005 at 9:25:34 pm
Hi folks-
Like the title sez! I am typing in words in Phsp.6.0.1 and ALL the fonts are typing in CAPS?! Can't find a menu item, style or preference to knock this out! Help! Try to use the Warped Text feature, I get the alert:
"Cannot complete your request because typed layer uses a faux bold style"
Thanks in advance!
Stu Aull
Alaska
Kim Mackenzie
Re: Can't get out of "FAUX BOLD" setting on fonts!
on Oct 23, 2005 at 9:38:42 pm
Yeah, faux bold is kind of hidden - this is a common annoyance (happens to everyone once).
Bring up the Character palette
Click the little arrow in the upper right of the palette to access the flyout menu.
Uncheck Faux Bold
Ta da
Stu Aull
on Oct 24, 2005 at 12:13:26 pm
"ta - da" Indeed!
Oh-so-obvious when you know where to look!!! :)
Thanks fellas!
regards'
Stu Aull
Richard Harrington
on Oct 23, 2005 at 11:01:01 pm
Look at character palette
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Sharlene Plescia
on Jan 18, 2016 at 5:12:16 pm
I am still using photoshop 6.0 because I can't afford to buy the newer versions. However, that is fine...it really is all I need.
I followed several suggestions to remove the faux bold setting in Character, however, after I reset that, I still cannot use the shape tool for text. It STILL says can't use due to faux bold setting. Help????
Kalle Kannisto
on Jan 21, 2016 at 10:53:03 am
By "shape" tool, do you mean "warp text"?
Considering it should work once you've removed faux bold, can you upload a file that you have this problem with?
