Converting Files for video.
COW Forums : Adobe Photoshop
Jon Himes
on Oct 19, 2005 at 8:40:33 pm
I know this has probably been covered somewhere else but I can't find it. I have numerous files that need to be converted to a DV size. I am open the files I want to convert in Photoshop and then open a new file and shrink the one I want to convert and copy and past it into the new file with the DV NTSC 480X720. Is there a batch processing technique because as you can see it takes forever. The Photoshop help is not that helpful in batch processing them.
Jon
Richard Harrington
Re: Converting Files for video.
on Oct 19, 2005 at 9:07:06 pm
Use the DVD slideshow action in PSCS2...
Look in actions palette.. laod built-in video actions
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Jon Himes
on Oct 20, 2005 at 1:45:36 am
Thanks for your reply,
Will this work with the non CS2 version. I have not upgraded from CS.
Jon
Richard Harrington
on Oct 20, 2005 at 12:54:51 pm
The actions ship with CS2... they work with earlier CS.. but you'd have to get them somehow
