how to make text (sentence or longer) go in a circle ?
COW Forums : Adobe Photoshop
janaipnai
on Oct 16, 2005 at 4:09:53 am
hi im in need to make an advertisment for my class but in order to do that i want my text to go in a circle...
i would like the paragraph which is about 5 sentences long, to go in a kinda of spiral. you know the kind that starts in the middle then you can follow it as it goes out.. is there an easy way to do it other than repositioning it over and over each word.. and also i want to make it curve.. so the spiral doesnt look jagged..
thanks a ton
Richard Harrington
Re: how to make text (sentence or longer) go in a circle ?
on Oct 16, 2005 at 2:28:53 pm
It's called Text on a Path
Since you didn't specify program or version.. that's about as specific as I can be...
Look it up in your textbook or in the help menu
And as a teacher, you really shouldn't turn to the Cow for help with homework
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
janaipnai
on Oct 16, 2005 at 5:00:04 pm
lol dont worry its not for a graphics class.. its for advertising.. =) but thanks anyways
