Alpha ?
COW Forums : Adobe Photoshop
Brian B
Alpha ?
on Oct 7, 2005 at 10:58:19 pm
Just new to Photoshop and was wondering how I can take an EPS file and convert it to a PCT with alpha intact?
Brian B
Editor
Avid|DS
http://www.trueindiefilms.com
http://www.lithia.com
Richard Harrington
Re: Alpha ?
on Oct 8, 2005 at 2:28:54 am
WHICH VERSION OF PHOTOSHOP?
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Brian B
Re: Alpha ?
on Oct 10, 2005 at 10:50:25 pm
CS2 is the version.
thanks
--brian
Brian B
Editor
Avid|DS
Richard Harrington
Re: Alpha ?
on Oct 11, 2005 at 1:16:59 am
Place the image over a transparent background with Place Command... then run the create Alpha channels from visible layers action (part of the Video set in the Actions palette - you may need to load it from the pull down menu)
Brian B
Re: Alpha ?
on Oct 11, 2005 at 11:24:59 pm
Thank you very much!!!!
Brian B
Editor
Avid|DS
Richard Harrington
Re: Alpha ?
on Oct 12, 2005 at 12:39:44 am
You're welcome... you might want to use the Inverted action since it looks like you are working on Avids.
