Tag or Not Taged
COW Forums : Adobe Photoshop
John Landry
Tag or Not Taged
on Sep 28, 2005 at 3:45:19 pm
I use photoshop cs2 mainly for photos that I use in my video editing software. I was told not to color manage the photos, so I have CS2 set to Off in color management. Everything has worked okay till I got a Epson 1800 printer. So my question is what should I use for a working space that I can use for video and also print a photo that matches my monitor. I should also add that I calibrate my monitor using Spyder Pro. Any help would I would be greatfull.
Richard Harrington
Re: Tag or Not Taged
on Sep 28, 2005 at 5:32:02 pm
Calibrate with the Spyder for your printer when doing print graphics
Turn color magement off whn doing video grtaphics
No all in one solution
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
John Landry
on Sep 28, 2005 at 6:38:33 pm
This maybe a dumb question but I am going to ask and also try it out myself. If I used Adobe RGB 1998 as my profile then the pictures that I am going to use in my video, could I just make a copy and convert it to NTSC profile, and presto everything looks great!!
Richard Harrington
on Sep 30, 2005 at 11:49:49 am
there is no ntsc profile
John Landry
on Sep 30, 2005 at 1:35:29 pm
I have one that says NTSC 1953 and another that saya Epson NTSC 1953 also found another on the net NTSC RGB 1953. I played around with them and was able to get good results, checking it with the cs2 video out. I am going to burn a disk with the three profiles and check the results on some different T.V.s. Was thinking of maybe picking up a NTSC monitor down the road.
Richard Harrington
on Sep 30, 2005 at 1:50:05 pm
I repeat... there is no such thing as color management and video... those are approximations and they are worthless
John Landry
on Sep 30, 2005 at 2:07:44 pm
My goal is to use CM for everything but video, but if you take a taged file and display it on a T.V. it looks like crap. I understand that it is only a approximation, if you display it on 10 T.V.'s you are going to get ten different results. My goal is to find the middle road as far as video goes.
