save as "jpeg" option not there in CS??
COW Forums : Adobe Photoshop
John Taylor
on Sep 23, 2005 at 9:18:41 pm
Hello,
I don't use this program much. I created a 16 bit grayscale .psd. When tryin to save as jpeg the option is not there. I recall there used to be many file formats available. There are only five in the drop down menu. Any ideas?
Thanks in advance,
JT
Kim Mackenzie
Re: save as "jpeg" option not there in CS??
on Sep 23, 2005 at 9:21:17 pm
JPEGs can only handle 8-bits per channel. So you'll need to save your 16-bit image in another format, or change to 8-bit to make it a JPEG.
John Taylor
on Sep 23, 2005 at 9:36:33 pm
Thanks so much for your prompt and informed reply!
John
Richard Harrington
on Sep 23, 2005 at 9:56:36 pm
Or use Save for Web Command
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
