selection corners
COW Forums : Adobe Photoshop
selection corners
on Sep 17, 2005 at 3:06:52 am
I know this is a ridiculous problem to have, but I have checked the manuals and can't find a thing on it. If I have a rectangular selection that I choose to modify, by expanding, or border, say, it takes what was a perfect corner and cuts it at a diagonal (stair-steps it). This is not really a video related question, as this is a portfolio for a designer, but I hope someone here knows how to get square corners when modifying, without going to manually fix each corner.
Any help would be muchly appreciated.
Richard Harrington
Re: selection corners
on Sep 17, 2005 at 3:28:25 am
Expand grows out alogn the pixel path... so it rounds out (or stair steps)
Use Select>Transofrm Selection (just liek Free Transform) You can drag handles or specify size in options bar
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from
edit - produce - direct -
© 2018 All Rights Reserved
