Batching RAW to JPEG
COW Forums : Adobe Photoshop
Todd Gipstein
on Sep 16, 2005 at 12:35:42 am
I have a bunch of canera RAW files I need to convert to JPEGs.
I have selcted them using the Bridge.
When the Action opens the RAW file, it stops, beause the RAW file needs to be OPENED or SAVED, where it appears in PhotoShop. But I cannot get the clicking on either the OPEN or SAVE buttons to be part of the action command.
Anyway, does anybody have an ACTION or suggestion as to how I can BATCH change a bunch 0f RAW to JPEG? Ideally, I'd also like to size thenm at 720 x 480 at 72ppi for use in Final Cut Pro.
Afvice, actions, or solutions most welcome!
"Born with the gift of laughter and a sense that the world is mad."
Richard Harrington
Re: Batching RAW to JPEG
on Sep 17, 2005 at 3:38:07 am
Look under teh automate menu for Image Processor...
also.. woudl suggest in your camera.. most of option to Shoot Raw + basic the basic is an identical JPEG.. saves a lot of work...
RAW files are meant to be 'devloped' manually so you can choose the dynamic range and otehr issues. Just batching to JPEG completely defeats the point of shooting RAW in the first place.
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
