CAn Photoshop do this? or do I need Debabeliazer?
COW Forums : Adobe Photoshop
Larry Watts
on Sep 9, 2005 at 1:26:56 pm
I jsut finished scanning 157 slides. I used a batch mode autname routine and have tif files with sequential filenames like DS050909213412.tif
where the year month date hour minute and second are assigned.
I want to do a batch process and convert the tifs to jpeg's with new names like BL001.jpg to BL157.jpg.
Can photoshop 7.0 do this?
If you know how can step me through it?
Larry
LSW
Richard Harrington
Re: CAn Photoshop do this? or do I need Debabeliazer?
on Sep 10, 2005 at 6:15:59 pm
It's part of the Batch Command... Look at the naming area...
Under OSX you can also do this with automator and it describes it pretty well in the built in help
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
