Photoshop vs. After Effects Color Problem
COW Forums : Adobe Photoshop
Damien
on Sep 8, 2005 at 6:59:22 pm
Hi. I took an Adobe Photoshopo CS2 file into After Effects 6.5 Pro and rendered a movie out of it. (After it was animated, of course.) I did this so that I can create a transition in DVD Studio Pro. However, the colors in Photoshop and After Effects are slightly different (one is slightly lighter). I made sure they are both RGB. Is there anything I can do to fix this problem? Thanks!
Richard Harrington
Re: Photoshop vs. After Effects Color Problem
on Sep 8, 2005 at 10:53:11 pm
Turn off Color Management in your PS color settings menu
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Richard Harrington
on Sep 8, 2005 at 10:59:02 pm
Richard Harrington
on Sep 8, 2005 at 10:59:08 pm
