"Could not complete your request because of a program error."
COW Forums : Adobe Photoshop
Dester Wallaboo
on Aug 25, 2005 at 6:18:14 pm
Preface: I have a vast amounts of experience in debugging software issues on computers.
OK... this is REALLY bizarre..... about a week ago I got this error while trying to save a file under Photoshop CS. It happened once... then went away. The very next day... I got the same error while trying to open any (and I mean) any file in Photoshop... I'm talking new files or old files, JPEG's, PNG's, TIFF's, etc. I deleted preferences, settings, all of that. Tried booting up without plugs installed, etc. All of the things one would typically go through to fix the problem. I even went so far as to remove every single Adobe application from my box (and all of their related support files) and reinstall everything. Exact same error. Then... intermittently... I could open or save files again... just to have it go back to the same problem as before. This was really bugging me. I then decided to try and run Photoshop that was sitting on another workstation via the network... exact same error. But even stranger than this is... that Photoshop that was running PERFECTLY previous to all of this... no longer works either!! It now shows up with the same error. Really, really bizarre.
Anyone else have this issue?
IsabelleVt
Re: "Could not complete your request because of a program error."
on Aug 28, 2005 at 5:04:11 pm
I started getting the same message yesterday when I tried to save some .psd files I had been working on. Couldn't find a way to get around it and lost them. I replaced the Preferences file with a backup copy I keep on my desktop and all worked as it should until later in the day when I tried to "save as" a file and got the same message. I tried just "save" and that worked. I don't know what is happening (or why), but hope I don't have to reinstall Photoshop.
Sounds like you're really knowledgeable, so if you find a reason (or fix) for the problem, please let me know. I definitely don't have knowledge about debugging, so need all the help I can get.
TerryL
on Sep 1, 2005 at 8:38:54 pm
Did you try using a Save As and renaming the photos? I had a similar problem and could not save photos, but only one set from a particular camera. Others were fine. It's not ideal but at least renaming the offending files in a Save As meant I could then use them as normal. They would open and save without problems. Also tried deleting preferences but did nothing.
IsabelleVt
on Sep 6, 2005 at 2:12:08 pm
Thanks, Terry, for your response. I haven't had a repeat of the problem, but if and when I do, I'll try your suggestion.
Cheers!
Craig White
on Jun 12, 2009 at 4:46:58 pm
I'm not sure how current this posting is, but I thought I would write to maybe help a few people out who are having this problem. I have noticed that when I don't have the proper fonts loaded in Photoshop CS3 for a particular file it will give me this error. Once I load the fonts the problem is solved. I use Suitcase for my font management. I was not sure which font was in the file that was causing the problem so I simply loaded all available fonts and voila! Problem solved. Hope this helps.
Greg Plummer
on Jun 30, 2009 at 2:22:06 am
I have had the same thing happen, very spuratic. For 3 months everything worked great. Now for the last two days I have been trying so hard to work, but Photoshop continuously crashes with the error message "Could not complete your request because of a program error." All I have to do is luanch the program and let it sit there and it crashes by itself with out me even moving the mouse... YIKES! Help! I'm calling Adobe tomorrow. One mor ething; I thought it would help if I uninstalled the creative suite 4 and re-install it... it didn't help, its the same!!
Robin Koontz
on Jul 7, 2009 at 2:37:11 pm
I had this problem too and found the solution/s here:
http://kb2.adobe.com/cps/331/331627.html
In my case, disconnecting my broadband modem did the trick. Weird.
Good luck! I feel your pain when programs misbehave while we're on a deadline.
Robin
Gayle Steinmetz
on Aug 5, 2009 at 4:13:22 pm
We are having this error at the present time in our business. Research found that the start up of Photoshop without the preferences corrects the problem only to have it reoccur periodically. Adobe customer service responded that Photoshop is not designed to perform across a server. If you have a server, move or copy your photo to your desktop. This is sad, considering most corporations use servers. However, try this and hope for the best.
michael kline
on Aug 28, 2009 at 4:19:17 pm
I had to delete some Asian typefaces that Firefox had installed. After that, no more problems, and Photoshop ran much better as well. Mac OSX 10.5.7, Photoshop CS4. Not really bagging on Firefox, it's great. Just watch those updates and what they install.
cris bucek
on Dec 17, 2009 at 7:31:07 pm
Hello guys!
After struggling for days with the same problems and even trying different versions of Photoshop I found the solution.
The problem probably happened after a printer installation...
Anyway, try the following steps:
Go to your Control Panel
Click on Printers
- Find the Microsoft XPS Document Writer
- Right click over it to open the menu and select "Set as Default Printer
- Re-start your Photoshop. Problem sorted!
Cheers,
Cris
zgura george
on Jan 29, 2010 at 2:53:03 am
cris bucek you were absolutely right my man.next time i'll drink a beer i'll think of you.simple problem,simple solution.i like your stile.
Mari Gom
on Mar 17, 2011 at 1:40:32 am
"Hello guys!
Click on Printers
Cheers,
Cris"
<<<<<<<<<<<<<< THIS WORKS!
Robin Craigen
on Oct 22, 2013 at 12:50:19 am
This was it!! Thanks~
Sara Hutchison
on Sep 15, 2011 at 9:40:51 pm
Thanks Chris! This worked for me! I had installed a new printer, got an error while trying to print, then started getting this error in Photoshop. I uninstalled the new printer, changed my default to Microsoft XPS and voila! Thanks again!
Glenn Colvin
on Apr 5, 2010 at 3:47:03 pm
Hey Michael,
Don't know if you're following this or not, hope you are. But, the question I have is did you delete the Asian Type faces in Firefox or in CS4? I have a user here that is having the exact same problem, not crashing but getting the error constantly, even when not running the program. Mac OS 10.5.8. Thanks for your help and have a good one.
Glenn
Pankaj India
on Apr 11, 2011 at 6:46:42 pm
bingo!!! you rock Gayle Steinmetz
Ohad Redlich
on Sep 4, 2010 at 9:11:50 pm
it happened to me when i was trying to save a JPEG file a friend sent me. i tried to edit and save, and got this error.
i found out the solution: under "file" menu, go to "File Info" it was marked as "copyright". change to "unknown" and delete any name that are there.
it will work for you then, i hope :-)
Ohad.
Arnold Resurreccion
on Dec 30, 2010 at 3:34:25 am
There is another way to go around with that problem in photoshop. First is to open the document in microsoft office picture then export it into different extension such as "tif" then open it on photoshop and save as to "jpg" extension, if that is the extension file that you wanted.
Ed O'Neal
on Nov 2, 2011 at 7:47:01 pm
This one worked for me. Thank you.
Ed O'Neal
on Nov 2, 2011 at 11:29:00 pm
The copyright solution worked for me. Thanks Ohad!
James Schooling
on Jul 30, 2012 at 4:01:19 pm
I had the same problem all of a sudden in the middle of a design session, and through the process of elimination traced it back to a font I used that I'd never used previously. I reset the PS preferences, which got PS working again, and deleted the font from my system. Everything is working great again.
Cherelyn Gillson
on Nov 25, 2014 at 1:46:54 am
Has anyone sorted out this problem yet? I have tried everything listed in this thread ie
  • change default printer
  • delete asian fonts
  • delete PShop preferences
  • Resave with different name
  • Check copyright settings
  • I have had no luck at all.
    Joseph Cralle
    on Feb 23, 2015 at 9:23:05 pm
    Same as Cherelyn, directly above; have tried each of these prospective fixes, yet none worked. Cannot save in any format. Exiting and/or re-booted provided temporary fix, but the problem re-occurs within a few more Saves. Surely someone knows. Why not Adobe? Don't they monitor these threads?
    John Ward
    on Jul 19, 2016 at 8:29:37 pm
    This may be occurring when trying to save pictures generated on an Apple product on a PC (font incompatibility). When I launder the iphone picture through IRFANview (load it and then save with a different name) it can then be manipulated and saved in Photoshop on a PC.
