no vanishing point in CMYK space?
COW Forums : Adobe Photoshop
illusboy
on Aug 20, 2005 at 5:47:40 pm
hello i made a picture with a digital camera that i converted to CMYK for print purposes in photoshop CS2.
The problem i'm having is that i can't use the vanishing point filter wen the image is in CMYK, why is that?
any help is appreciated.
illusboy
Richard Harrington
Re: no vanishing point in CMYK space?
on Aug 20, 2005 at 11:17:51 pm
Many filters only work in RGB space...
Copnverting to CMYK is the FINAL step... it is best ro work RGB throughout (faster processing, more options, etc.)
Converting back to RGB from CMYK won't shift colors.. the shift occurs when going to thCMYK the first time as RGB has a wider gamut.
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
illusboy
on Aug 22, 2005 at 9:14:27 am
thanks i did not know that!
