Merge alpha channels?
COW Forums : Adobe Photoshop
on Aug 10, 2005 at 7:54:01 pm
I know there is an option to merge alpha channels, BUT PSHOP never allows me to do it...anyone know how to do this??
Richard Harrington
Re: Merge alpha channels?
on Aug 11, 2005 at 3:17:02 pm
Calculations command can do it
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from
edit - produce - direct -
Eric Chard
on Oct 24, 2007 at 6:24:31 pm
Indeed, and thanks!, although it's pretty FRIKKIN annoying that the IMAGE/CALCULATIONS command is ghosted if two alpha channels are selected. (grrrrrrr)
WUWT, Adobe???
Michael Ebert
on Aug 15, 2005 at 3:36:35 am
I often prefer to do it myself - i.e., Ctrl-click (or Command-click on a Mac) on an alpha channel to select its contents - then go into another channel and either fill that selection with white or black as needed. Hope that makes sense...
// love what you do or do something else. //
Michael Ebert -- graphic designer, jazz saxophonist, horror movie devotee
© 2018 All Rights Reserved
