tabs in ps
COW Forums : Adobe Photoshop
s!
tabs in ps
by
on Aug 10, 2005 at 1:06:15 am
Is there a tab function for photoshop text? Can i set the tab length etc?
Cheers!
Richard Harrington
Re: tabs in ps
on Aug 10, 2005 at 2:00:47 am
Nope.. can't set it
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
s!
Re: tabs in ps
by
on Aug 10, 2005 at 5:39:08 am
Cheers Richard!
I really wish there was. I've often need to do a lot of text editing in photoshop and find it pretty labourious. I'd also love it if there were some sought of style sheets, so that i didn't have to manually change fonts continually.
Anyway, wishful thinking!
Richard Harrington
Re: tabs in ps
on Aug 13, 2005 at 2:04:26 am
Try copying blank spaces to your vlip board and paste.....
However... in the Paragraph tab.. you can set an indent.... so look there and see if that will do the trick
