Gradient question
COW Forums : Adobe Photoshop
Gradient question
on Aug 9, 2005 at 4:25:49 am
Can you put more than one Gradient in an ellipse or other Vector shape?
I need Gradients like in fireworks Ripple, Waves...
Thanks for any help
Kim Mackenzie
Re: Gradient question
on Aug 9, 2005 at 11:13:09 am
More than one gradient per layer, no, but you can put additional gradients on layers above, then change the blending modes on those layers so they'll modify the layers below.
If you group the layers (in the layers palette, option or alt click between the layers), then the layers above will be masked by the bottom layer.
Richard Harrington
on Aug 10, 2005 at 2:01:31 am
You can add a gradient fil layer and paly with the scale command
or you can edit the gradient with the gradient editor and just repeat ABABABAB
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from
edit - produce - direct -
© 2018 All Rights Reserved
