adobe - batch converting?
COW Forums : Adobe Photoshop
mali
by
on Aug 8, 2005 at 5:45:21 pm
how to specify size in doing batch converting?
where to specify?
and
how to specify size ?
i start with 27" x something,
how to reduce to 4x6"
help!
thanks,
mali
Jeff Cochran
Re: adobe - batch converting?
on Aug 8, 2005 at 6:00:23 pm
When writing your script, go to image pull down> image size
Jeff Cochran
http://www.jeffcochrandigitalartist.com/
mali
by
on Aug 8, 2005 at 6:13:44 pm
But how do I write a script which will automatically
change the size of a BATCH of photos?
mali
by
on Aug 8, 2005 at 6:22:07 pm
let me add - in Photoshop CS. Thanks.
Jeff Cochran
on Aug 8, 2005 at 6:33:33 pm
When writing your script, use image size to change the size. you can change size by inches, percentage or pixels.
The change in size will be written into the script and will be applied to all images you batch with this script
Jeff Cochran
mali
by
on Aug 8, 2005 at 7:00:43 pm
Sorry but how do I write a script?
Jeff Cochran
on Aug 9, 2005 at 4:02:32 am
Under the window pull down>Actions
Create a folder, then start recording. Every action you take will be recorded. Then under file>automate> batch. You can select the script you created to apply to a large number of images
Jeff Cochran
