grfx fixin'
COW Forums : Adobe Photoshop
Maryanne Hamill
grfx fixin'
on Aug 8, 2005 at 5:25:55 pm
This might be really simple but I'm curious how other people do this.
I get grfxs all the time that are flattened with a white background. I usually have to seperate the white from the main grfx. I do it by using the magic wand tool & selecting the white. Then I delete the white. This usually leaves an edge of white around the grfx or else jaggy edges. Then I have to some what recreate the grfx in order for it to look decent. What's another way that I can remove a white background?
By the way I'm on a G5 panther using PS CS if that helps.
Thanks in advance,
Maryanne
Richard Harrington
Re: grfx fixin'
on Aug 10, 2005 at 2:07:05 am
Several ways
Here's Three
http://www.photoshopforvideo.com/content/videos/Alpha_Channels.mp4
http://www.photoshopforvideo.com/videos/psnle/13_Alpha_Channels.mov
http://www.motioncontrol3d.com/videos/psnle/15_Calculations.mov
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Richard Harrington
Re: grfx fixin'
on Aug 11, 2005 at 3:17:39 pm
You're welcome
Close the loop
